CARB IDLE
Jeff somethings you might check is..
Fuel pressure 7 psi
Idle screws out 1 1/2 to 2 turns
Make sure your needle seats are not running over
Check for vacuum leaks
Check vavle lash
I've seen guys drill an 1/8 hole in the butterfly to help to keep their engine from loading up.
A few things to check...........
Fuel pressure 7 psi
Check vavle lash
If turning the idle screws out another 1/2 turn fixed your idle, then you were to lean. The idle screws are a minimal change so your probably still a littel lean, if you have removable air bleeds on the top of your carb. You can put a smaller air bleed in the most outside air bleed from the vent tube to richen your engine at idle alittle more. Otherwise your probably going to have a bog at launch.
I HAVE REMOVABLE AIR BLEEDS AND BOGGING IS A PROBLEM AS YOU CAN READ IN MY OTHER POST.IT LAUNCHES STUTTERS AND GOES DOWN THE TRACK FINE,LAST NIGHT COMING UP PIT ROAD IT HAD A MISS ALSO IT BACKFIRED THRU THE EXHAUST WHEN I LET OFF THE GAS AFTER MY RUN.
#20
Originally Posted by JEFF69Z28
950 HP BODY 840 CFM CANT REMEMBER JET SIZE AS IM AT WORK.50 CC PUMP IN FRONT AND 30 CC IN REAR SQUIRTERS ARE 40 FRONT/40 REAR.
