Band adjustments on PG's
Old 07-17-2009, 01:08 PM
TheRabbit
TheRabbit's Avatar
Originally Posted by johnracer
So you've done that too eh? I usually do that kinda thing in eliminations though. I've run outta gas, forgot to turn on my co2 bottle, launched in neutral, (my favorite and thank god for rev limiters), had the chute fall out at about 100ft, shifted into reverse at 125mph (don't try that one, REALLY scary and crashes happen), forgot to turn the delay box on, entered wrong dial-in using crosstalk, and on and on......fortunenately I haven't done any of those things in quite a while.
Dparker is correct again, you can't follow everyone's advice. Kinda like machinists, and engine/tranny builders; pick someone you trust and stick with em.
Johnny
Reverse @ 125mph!! OUCH!
TheRabbit is offline
Old 07-17-2009, 01:21 PM
fla1976
fla1976's Avatar
Default Reverse @ 125
I saw a car that also got put into reverse at the top end at Bandimere in 1986. Luckily it had a good cage. Totalled the car though. I was told he wanted to put it in neutral so he could get a better reading on the plugs.
fla1976 is offline
Old 07-17-2009, 03:27 PM
TheRabbit
TheRabbit's Avatar
I didn't think it would go into reverse or not go hard into it anyway.
I've hit my trans brake after I've taken off before. IT SUCKS WHEN YOU'RE A 4 WHEEL DRIVE!! It locks you down HARD! Also have hit it while backing up and turning around so I put a toggle switch in line so when I'm backing up a long way I just flip the switch.
Old 07-17-2009, 04:09 PM
shawnp
The only place that R is far enough away from N to be safe is in the alphabet.
shawnp is offline
Old 07-18-2009, 04:01 AM
johnracer
Default Re: Reverse @ 125
I always shift into neutral after the stripe, but really smacked the shifter hard on that one! Didn't total the car, but sure scarred it up. Not to mention the car in the other lane and the guardrail........not one of my finer moments and a really crappy way to make friends and influence people.......I shift into neutral very gently now
johnracer is offline
Old 07-18-2009, 03:44 PM
andybyrd
Man that all makes me feel better I really thought I was the only one that could of ran out of gas of all things. but I really like these stories makes me feel normal again.
Thanks guys Andy
andybyrd is offline
Old 07-19-2009, 03:11 AM
johnracer
Yep, sucks being human..........how about cutting a perfect light, then breaking out by taking waaaay to much stripe? That'll make you feel like a goober.....hero to zero in one pass!
Old 07-19-2009, 06:33 AM
  #18
TheRabbit
TheRabbit's Avatar
Did you have to mention the Red light? Last night I made it to the final round and red lighted :evil: :evil: . What's so bad, I red lighted in the round before and the other guy did too, but worse and he broke out. Then I did it agian :x :cry: But, I almost ran my dial in perfect every time. + .001 or .002 on 5 of my 7 passes.
Old 07-19-2009, 06:48 AM
  #19
Tod74
, had the chute fall out at about 100ft, Johnny
:lol:
Tod74 is offline
Old 07-19-2009, 07:24 AM
  #20
fla1976
fla1976's Avatar
Default oops
Had a slick go flat after the burnout. Don't know why. Screwed rims and proper pressure. Filled it up and it never happened again. Embarrassing just the same. ops:
fla1976 is offline
