Drag Racing Frustration!! Car Trouble
Old 08-18-2009, 03:35 PM
ashbros
Seems to me if it was a little plugged up, your fuel system is now contaminated.
Clean out all fuel filters, pull the bowls off the carb, clean them out and blow out all your fuel lines from tank to carb.
ashbros is offline
Old 08-18-2009, 05:27 PM
sstougard
APPRENTICE
I'll buy that, will do and post results. Thanks guys, for helping.
sstougard is offline
Old 08-18-2009, 06:25 PM
TheYellaBrick
TheYellaBrick's Avatar
If ya have foam blocks in the cell that are more than a couple of years old, REPLACE them. That foam breaks down a little each year and can cause all sorts of havoc.
TheYellaBrick is offline
Old 08-18-2009, 08:33 PM
ashbros
Double D is preaching the gospel in regards to fuel cell foam. Pay Heed....
ashbros is offline
Old 08-18-2009, 08:49 PM
Tod74
DAMN...MINE IS 8 YEARS OLD. :?
Tod74 is offline
Old 08-18-2009, 09:05 PM
DirkaDirka
DirkaDirka's Avatar
Ok why is there foam block in the fuels cells anyways?? What job do these blocks have? I dont know just wanna learn something new form the masters of racing. So teach me O' mighty ones.
DirkaDirka is offline
Old 08-18-2009, 10:27 PM
ashbros
Baffling or safety foam, It slows fuel cell slosh while providing explosion resistance.
Cell Slosh - Designed for all types of racing including drag racing or circle track racing, safety foam will keep your fuel pump from being starved under hard acceleration or cornering.
Explosion Resistance - If your cell were to become damaged, i.e. in a crash, the foam kind of retains the fuel causing it to drip out of your leaking damaged fuel cell instead of gushing out.
Some even go as far to say that the safety foam keeps weight transfer/shift to a minimum, which provides you with more responsive and predictable handling.
See this link...
http://www.reillyfoam.com/safety.htm
ashbros is offline
Old 08-18-2009, 10:32 PM
  #18
DirkaDirka
DirkaDirka's Avatar
I see now. Now how much foam is in the cell?
Old 08-18-2009, 10:40 PM
  #19
ashbros
It depends on the type of fuel cell you have.
Here are a couple links for fuel cells.
http://www.fuelsafe.com/faqs.htm
http://www.jazproducts.com/faqs.html
http://www.rjsracing.com/fuelcells.html
:idea: :idea:
ashbros is offline
Old 08-19-2009, 05:47 AM
  #20
Tod74
mine is completely full with a small hole in the middle. It's just a giant sponge basically.
Tod74 is offline
