bbc motor smoking
Old 09-15-2009, 10:57 PM
cepx111
X2
White smoke = antifreeze/water - tranny fluid
Blue smoke = oil
Black smoke = fuel (rich)
cepx111 is offline
Old 09-16-2009, 03:20 AM
CamBirdRacing
Another thing to think about- if they used oil on the rings to assemble the engine, might be the oil between the rings burning off. I always WD40 the cylinder walls and put the pistons in dry. Never had a problem this way. Just with fram filters.
CamBirdRacing is offline
Old 09-16-2009, 04:45 AM
ss68nova
APPRENTICE
Default bbcmotor smoke
im running water only no antifreeze,trans fluid running to a cooler, did a leak down and all cyl ad 0 percent leak, and its blue smoke not white,i will do a compression test he used total seal rings, thanks
ss68nova is offline
Old 09-16-2009, 05:37 AM
chevynovaman
SENIOR BUILDER
chevynovaman's Avatar
ALSO ONE TIME MY ENGINE WAS SUCKING OIL THROUGH THE VALVE COVER, THROUGH THE PCV VALVE INTO THE CARB.. POSSIBILITIES,, WRONG PISTON WALL CLEARANCE, RING GAPS, VALVE GUIDE CLEARANCE.. OR BEAT THE BAT HELL OUT OF IT AND SEE IF THE RINGS SEAT..... GOOD LUCK...
chevynovaman is offline
Old 09-16-2009, 05:41 AM
JEFF69Z28
Default Re: bbc motor smoking
Originally Posted by ssmonte70
hi, i had a local machine shop build a 540 chevy motor pump gas with merlin aluminum heads, i started the motor and it smokes, did a leak down and leaks down ok, changed the intake gasket and still smokes , any suggestion, thanks
TAKE IT BACK TO THE BUILDER IF YOU JUST GOT IT BACK.
JEFF69Z28 is offline
Old 09-16-2009, 05:10 PM
ssmonte70
APPRENTICE
Default bbc motor smoking
a blown head gasket would the cause to smoke on both sides, and how would fuel get in the oil, to much jetting in the carb, the plugs look good , no water in the oil, the motor only has about 3 hours of running time, but i never seen a new motor smoke like that even if you need to break in the motor, for the rings to seat,
ssmonte70 is offline
Old 09-16-2009, 05:50 PM
FullTimeRacing
post a video
FullTimeRacing is offline
Old 09-16-2009, 05:52 PM
  #18
fla1976
fla1976's Avatar
Default Smoke
A blown head gasket would burn oil on the side that was blown. Is it burning on both sides? Were the valve seals replaced? Sometimes the little things get overlooked. The intake could be leaking and pulling oil in from the valley.
fla1976 is offline
Old 09-16-2009, 06:19 PM
  #19
ejm
SENIOR BUILDER
im just wondering who actually posted this? ss monte or ss nova? good luck to whom ever it is
ejm is offline
Old 09-16-2009, 06:20 PM
  #20
FullTimeRacing
:shock: :? :? :? :lol: :arrow:
