Antiroll Bar
Old 01-09-2012, 02:01 PM
bbchevy
Default Bar
Originally Posted by coolracing
Thanks Rabbit just ordered one from RJ Race Cars I went with the Pro Series kit. Was a little more cost eff.
Thats PROBABLY 1 of the Nices Kits on the Market!
Later
G 8)
bbchevy is offline
Old 01-09-2012, 03:05 PM
TheYellaBrick
TheYellaBrick's Avatar
Re; cracked arms,
Those cars probably had a BUNCH of suspension compression from soft springs, coupled with a TON of torque that wanted to cause a lot of body roll, and maybe too stiff an anti roll bar. All that together against the anti roll bar and SOMEthing is under WAY high stress , arms and splines.
We've all seen that 60's Belair that launches so hard it looks like it's gonna flip over sideways. THAT is the kinda action I'm talking about. If he had a little stiffer rear springs along with an anti roll bar, he'd launch flatter and his 60 foot times would dive. All that energy to twist that body and lift that one front tire, put into forward motion would result in overall faster times.
This one here. watch how much time he spends just gettin' outa the hole. Imagine how high the pucker factor is driving this !
-http://www.youtube.com/watch?v=aJA_urCmSls
http://www.youtube.com/watch?v=mV4_H...eature=related
TheYellaBrick is offline
Old 01-09-2012, 06:17 PM
coolracing
Originally Posted by DrivingMissDD
Re; cracked arms,
Ya he is a regular at my home track WIR he is more about putting on a good show then runnin a good number. But I got to admit he is a crowd pleasure! I get when ur comin from with that Double D.
coolracing is offline
Old 01-10-2012, 11:46 AM
fast75vega
Originally Posted by zipper06
. Just curious as to why you think they it will help, it doesn't soulve chassis twist.
thats exactly what i seen it do.... cars i seen leave damn near lvl with them in the rear and b4 had the left wheel up and the right still on the ground and bar was the only thing changed :wink:
fast75vega is offline
Old 01-10-2012, 02:29 PM
bbchevy
Default ?
Well,I'll Be the Test Mule on this!
Cause I Have a Kit on the Way!!!
My Chassis Guy is 1 of the BEST in the Business,He set my car up.After seeing several Picts with the Left Frt.3' in the Air and the Right skiming the Pavement?
He Told me?G,we NEEDS a Anti-Roll!!!!!!!
So,.................?
Later
G 8)
bbchevy is offline
Old 01-11-2012, 02:33 AM
JEFF69Z28
Default Re: ?
Later
G 8)
And a 14 point roll cage to stiffen the body up and for saftey.
JEFF69Z28 is offline
Old 01-11-2012, 06:41 AM
TheYellaBrick
X2 on the cage. Figure that a full length cage system as a 'bridge'. It will make your whole platform rigid and stable, allowing for more accurate and consistent suspension tuning. Also think TRIANGULATION as that is the STRONGEST and safest !
Old 01-11-2012, 07:13 AM
  #18
bbchevy
Default ?
Well IF it were a Full Tube Car that would Not be a Issue?But for Now the 12pt Cage will have to do!
Being that MOST of My Problem is Body Roll and Not Chassis Flexing,we will Deal with IT?
In all Reality,Its only about 12-14" difference from Left to right.If it was 36"s then there would Obviously be Other Issues!!!
THANKS!
G 8)
bbchevy is offline
Old 01-11-2012, 07:50 AM
  #19
TheYellaBrick
A 12 point is way better than a 4pt. You'll be fine. Keep us all posted on your progress and trials and tribulations. Remember that you do NOT want to adjust a bunch of preload as this will REALLY stress the arms and splines.Let it work naturally as designed. You will probably be trying different spring rates left to right.IE; a tad stiffer on the right and good/new adjustable shocks.
Set up a base line and KEEP ACCURATE NOTES on each and every adjustment noting the results. ONLY make ONE adjustment at a time, as you can get totally lost if you make more. Make this a science project cuz it takes this approach to be fast and CONSISTENT ! It WILL pay off.
HAVE FUN !!!!
Old 01-11-2012, 08:21 AM
  #20
JEFF69Z28
Default Re: ?
THANKS!
G 8)
What kind of car is this going on?
