BBC BLOCK W/ O RINGS, ANY HEAD GASKET BESIDES COPPER?
Originally Posted by bowler
Zip and Mark thanks again for your help, yep I did use a cheap torque wrench with bolts (came with arp bolts), the one thing that I did not do was re-torque!, only reason that I pulled the heads was to have them ported and all looked good except 1 chamber (white specs), I will call Al about cutting receiver grooves in the heads. Thanks again Doug
I don't use ARP studs because there are cheaper ones out there that work just as well.
Zip what brand of studs do you use just wondering.
What about main studs next time I go thru my motor ( hopefully next winter) I thought about studding the motor not trying to steal the thread.
Zip I was looking for head studs, only found procomp or arp? Doug
http://www.ebay.com/itm/New-ProComp-...#ht_1272wt_822
