RESPONSE FROM TESTA1 TO 1923T
Old 02-06-2008, 08:53 AM
  #21
undertakerii
Testa, :roll: Who in their right friggin mind would return anything to you for a full refund at this point and time? You've already proven to be a SCAMMER so who would want to risk losing anymore than they already have. If you're trying to indicate that perhaps the parts went missing after the Michigan recipient receieved the parts-dream on. As for Dennis being in Canada and you not having his home address, I believe you got your money and it cleared the Bank, its alot quicker and cheaper to have parts sent to a friend in Michigan then it is to have them brokered into Canada. As you probably know Canada is geographically larger then the U.S., but Dennis is a mere 15 minutes away from the Michigan recipient and not all that far from you. Do the right thing and send the missing parts.
undertakerii is offline
Old 02-06-2008, 10:15 AM
  #22
keepinup
hello,
Sounds like you know the the guy in Canada,?
keepinup is offline
Old 02-06-2008, 10:59 AM
  #23
topsportsman1
Administrator
Originally Posted by "keepinup"[/quote
hello,
David Testa thanks for for input here :P
topsportsman1 is offline
Old 02-06-2008, 11:07 AM
  #24
Scorpion1110
TopSportsman1, it sounds like you may be checking static IP addresses
Correct assumption?
Scorpion1110 is offline
Old 02-06-2008, 11:09 AM
  #25
topsportsman1
Administrator
Correct assumption?
That would be correct.Can you say busted? :P
Old 02-06-2008, 12:17 PM
  #26
mcracecars
:roll: man .... i gotta start reading these posts early on.... 2 pages , just so confusing now :?
mcracecars is offline
Old 02-06-2008, 05:13 PM
  #27
mopar1968
mopar1968's Avatar
Default scam scam scam
Well seems folks here on RJ has voted- SCAM SCAM SCAM !!!!!!!!!!!! :shock: :shock: :shock:
mopar1968 is offline
Old 02-06-2008, 05:17 PM
  #28
shawnp
Between this deal with Testa and Bigtoys454/weissberg this forum is getting next to impossible to figure out the good from the bad.
Tom, can you use that magic delete button and clean some of this garbage up so the forum is a little more reader friendly??? Thanks.
shawnp is offline
Old 02-06-2008, 05:30 PM
  #29
lotsof454sss
Not only a SCAM but running under another user id too...BUSTED his ass Mr. Tom... :lol:
I guess testa (keepinup) thinks he is oh so smart and got busted...
lotsof454sss is offline
Old 02-06-2008, 06:08 PM
  #30
mopar1968
mopar1968's Avatar
Default scam
Now talking about not being able to keep up with this, now i am curious to see what his next post will be? Is his face ops: ops: yet?
