Oil pressure
Old 12-19-2009, 08:27 PM
  #21
mopar1968
mopar1968's Avatar
No the rocker setup is just like chevy's each one has a bolt to hold to head, oil's thru pushrods like chevy's, now that is one thing i haven't looked at, the mounting of pump to rear main might be something there oil spraying back to pan Hmmmm, Well, Well
mopar1968 is offline
Old 12-19-2009, 08:36 PM
  #22
MEMRACING62
I would say fla1976 may be on to somethink there :idea:
MEMRACING62 is offline
Old 12-19-2009, 09:01 PM
  #23
dragonmaster093
too bad they didnt make a see through pan to see if that was the issue of course guy could take an old pan cut a window in it an use peratex and rivits with a peice of plexi glass to make one
dragonmaster093 is offline
Old 12-19-2009, 09:04 PM
  #24
mopar1968
mopar1968's Avatar
Now that is a idea, could make one pretty quick, plexiglass with some sealer.
Old 12-19-2009, 10:15 PM
  #25
kwkracing
i posted my problem exactly like this, with a sbc, that turned out to be a oil galley plug with a minor leak, but when the oils warm it squirted out which lost all oil pressure
kwkracing is offline
Old 12-19-2009, 10:49 PM
  #26
Originally Posted by mopar1968
I am thinking a oil passage is cracked somewhere in the block, This job is now costing me money, Lossing my A$$ on this one. No lifter bore's checked out great engine had 134,000 before rebuild.
''JUST MY TWO CENT'S WORTH''
X2, have you checked to see if the rear main cap is cracked. I'm not a mopar person although i've owned and rebiult a couple of them. I don't see a solution without pulling the bottom end down and looking at everything. If the lifters are banging at idle then i don't think it's the gage.
Old 12-20-2009, 04:05 AM
  #27
fla1976
fla1976's Avatar
Does the engine have galley plugs behind the timing cover like the small block Chevy. If it does, I would agree with KWKRACING and MANIAC that it may be the problem. There is no obvious leak that is visible, but the oil is not going to go to the top end.
fla1976 is offline
Old 12-20-2009, 05:52 AM
  #28
MEMRACING62
http://www.youtube.com/watch?v=Jz1Z-AS5H1M kw's oil leak video
Old 12-20-2009, 06:19 AM
  #29
itsabird
don't know much about mopar,s, but could there be a problem with gear attchment to the secondery pump shaft? just a thought, good luck.
itsabird is offline
Old 12-20-2009, 07:15 AM
  #30
THERATTLER
THERATTLER's Avatar
check out this page http://www.forabodiesonly.com/mopar/...ad.php?p=68234 they are talking about loose oil galley plugs causing low pressure.. read the whole thread , they talk about 2 different ones...hope this helps
THERATTLER is offline
