got the vega runnin....
Old 09-29-2011, 07:10 AM
  #31
mwbrasher
JUNIOR BUILDER
hey big ray... i've got a timing lite... that is what i used to set it at 38... was just saying i adjusted it by "ear ... where it sounded good"... found it was WAY ADVANCED....like 48... that is my problem... 34-38 it goes slower.... thanks caveman :? :? :?
mwbrasher is offline
Old 09-29-2011, 07:29 PM
  #32
bigray
hummm 48 and it still likes it, and it doesnt back lash the starter,, i would think its got the wrong balancer or the wrong pointer or something, i would pull the #1 plug and really check for TDC and make sure that TDC is in line with the pointer at 0 degrees or at least close to it,,
bigray is offline
Old 10-05-2011, 04:10 PM
  #33
mwbrasher
JUNIOR BUILDER
well... went to the dyno today.... the car has 298.7 hp.... timing was at 30... set the timing to 38.... went 299.7 not enough differance to run that high of timing.... only gained 1 hp of torque... vang... the dyno guy said to run a much hotter plug and set timing on 32....the car will be dead on...also my fuel ratio was 13.3... at w.o.t..... the fuel is not burning...thats why a hotter plug... any more help would be great!!!! i'm open to suggestions... but the motor is only a " 331" c.i.... thanks caveman... :lol: :lol: :lol:
Old 10-23-2011, 07:27 PM
  #34
mwbrasher
JUNIOR BUILDER
hi every one.... well went to the races last week... changed the setting on the 4 kink... car runs consistant 1.59 60 ft and 11:70 at 112 to 114 mph car is pulling front wheels up about 6". on launch... do you think going to a tunnel ram and 2-660 center squirters would help lower my et.... any sugustions would help.... thanks caveman... :lol: :lol: :lol:
Old 11-17-2011, 05:38 PM
  #35
csx8506
SENIOR BUILDER
what type of heads do you have? Have you had any port work done on them? What size primarie's and collector size? As far as your total ignition advance, if you don't run 38 to 40 degrees or more, as Zip said, your engine will not rev up quickly, everything else being equal.
csx8506 is offline
Old 11-17-2011, 07:27 PM
  #36
TheYellaBrick
TheYellaBrick's Avatar
From what I've gathered over the years, although I could be waaay out in left field ;
Dual quad tunnels usually work best on high winding engines, consequently the airflow volume is way high. High flow heads and exhaust are instrumental in overall performance.
TheYellaBrick is offline
Old 11-20-2011, 07:19 AM
  #37
mwbrasher
JUNIOR BUILDER
hi all... i am running world product sportsman ll heads... 200 runner and 2.02 intake valve... with 5.14 gears ... through the lites at 7000 rpm...pulls all the way... no miss... just trying for a better et... thanks caveman
