Powerglide leaks fluid 2 days after racing
Old 07-20-2017, 06:42 AM
lodilobo
Default Powerglide leaks fluid 2 days after racing
I have a pretty well built powerglide with aftermarket 180 gears, trans brake, recently rebuilt. It never leaks trans fluid while racing / running, but a couple days after, I will see a large area of trans fluid on the floor, with no indication where it came from. The pan gasket is sealed, the lines do not leak, the convertor seems dry. Any ideas?
lodilobo is offline
Old 07-20-2017, 06:10 PM
Swiley383
Swiley383's Avatar
Could it be draining out of the cooler and running out the dipstick tube?
Swiley383 is offline
Old 07-20-2017, 06:47 PM
jayvee34
SENIOR BUILDER
jayvee34's Avatar
Check the vent. If clogged, pressure will build and push fluid out.
jayvee34 is offline
