front end shimmy
APPRENTICE
I have a 98 camaro with a big block chevy engine. wilwood brakes all around. Stock front struts. Problem is after running 1/8 mile even if i just touch the brakes the steering wheel shimmys. The harder i push the harder the wheel shimmys. while coasting after run the car is fine. But touch brakes and woww look out. I've taken off rotors and put them on a brake lathe. perfectly straight. Put tires on a balancer and no problem. Realigned front end. nothing. cleaned rotors with 100 grit air sander. Bought new pads. Oh i have 10 runs on this setup. Shimmied 9 times. New bushings new tie rod ends, stock rack. I''m at wits end.,.could front end toe in be wrong for the big block chevy at 122 in 1/8. Stock factory setting on front end specs for alignment. Any suggestions will be appreciated. I'm sure this isn't something only i'm stuck with.
Turn the rotors with an on car brake lathe. There is probably some run out on the face of the hub causing the issue. Turning on the car eliminates that problem and cuts them straight on the car.
Chris
Chris
I’d look beyond rotor runout. Under hard braking, heat can expose a loose/worn hub bearing, ball joint, spindle, caliper mount, or flexing stock strut/control-arm setup. Check wheel bearings and all fasteners hot and cold. Also verify toe under load; factory specs may not suit a drag setup. A dial indicator on the hub/rotor can help isolate it. Looking for a place to stay updated on sports betting? Betting Site BD brings all betting app https://telecomasia.net/sports-betti...es/bangladesh/ betting-related information, odds, and sports coverage together in one place. Follow the latest match insights and explore the world of online betting responsibly
