Into the 12's
Old 08-05-2007, 06:29 AM
chevguy65
Default Into the 12's
Now to do some tweaking and yahoo.....
Went out Friday in 100 degree heat and bad air and this is what I ran...
I know they are hard to read but I ran a 13.02 @ 104, a 13.04 @ 103, a 13.04 @ 104 a 12.98 @ 103. My 12.98 pass I let off so I didn't break out to much, I was on a 13.01 dial.
My R/t's were .176, .016, .005 and .157.
My 60's were slower, I was getting spin out of the hole but were, 1.83, 1.83, 1.85, and 1.82.
All in all it was good, went 4 rounds and if I had not hit my rev limiter in the last rd I would have gone to the semi's at least.
All this in the heat and bad air.
chevguy65 is offline
Old 08-05-2007, 07:57 AM
bignastygs
SENIOR BUILDER
Is that with slicks or street tires?? The heat sure tames a good running car though.
bignastygs is offline
Old 08-05-2007, 08:19 AM
chevguy65
MT ET Street Drag Radials.....I was heating them up well but they just spun.
Footbraking and no preload.
Old 08-05-2007, 08:57 AM
woodsman
Carl that is some great #'s its getting better all the time. Is that your fastest time so far with your hotrod. With some good air an tweeking here an there I can see 12.80's coming down the strip. You never know I may see you at the tree one day.
woodsman is offline
Old 08-05-2007, 09:04 AM
chevguy65
Thanks Wes, 8)
I think mid to low 12's with some tweaking and open headers.
When I shut off I was about 108mph.
Is that your fastest time so far with your hotrod?
Yes, so far.
Better be on your toes, I am cutting some awesome lights :shock: :P :P
Old 08-05-2007, 10:00 AM
cepx111
Try some ET slicks or the ET street slicks if its a street car, ditch the radials they are notorious for spinning, especially in the heat.
If you ever do figure what those radials like E.G. heavy burnout, light burnout, hazing, dry hop, flashing the stall, varying launch rpm, playing w/ air pressure settings etc etc etc, they will drive you up the wall trying to find out what they like to get them to hook, then when you do get it right and they do hook a few rounds they will let you down at the most unopportune time E.G. money rounds, semis, finals etc etc etc. save your self the headache and get some slicks, your lights more consistent et's and your sixty foot times will thank you.
Been there done that, Charles
cepx111 is offline
Old 08-05-2007, 10:42 AM
  #7
mcracecars
happiness is a 12 sec street Chevelle
mcracecars is offline
Old 08-05-2007, 10:54 AM
  #8
woodsman
cepx111 that was a great post with the advice I myself can use that info when I get mine running. Experience is a valuable thing.
woodsman is offline
Old 08-05-2007, 11:24 AM
  #9
bignastygs
SENIOR BUILDER
OR BUICK.... I wont be happy till I see 10's in mine...
Old 08-05-2007, 11:40 AM
  #10
Good to hear you got it down some, if the money is available i would go to 9"X28.5" mickys they will fit with the correct offset rim. That's what i used to run and mine went 11.50's all day long with a mild rat motor and pull the front wheels.
I hope you have C-Clip eliminators on those rear axles . It would be a shame to mess up that beautiful body on the 65 :shock:
