Electric fuel pumps, do i need a regulator?
Old 09-08-2007, 04:57 PM
Blue68Camaro
JUNIOR BUILDER
Default Electric fuel pumps, do i need a regulator?
What is the purpose of a regulator?
Thanks,
Tom
Blue68Camaro is offline
Old 09-08-2007, 06:08 PM
Yes you need a regulator, because most good electric pump are capable of puting out 12/14lbs of pressure and that sometimes will blow by the neddle and seats in the carb. Most people set the regulator at 8lbs.
Old 09-08-2007, 06:31 PM
jbsjunk
If you're going on the cheap, Holley and Carter among others make a pump that doesn't need a regulator, Holley's red pump for example, I've run those alot with no issues.
jbsjunk is offline
Old 09-08-2007, 06:46 PM
Blue68Camaro
JUNIOR BUILDER
I have the holly blue pump as well as the mallory 140 series i think it is.
Old 09-09-2007, 01:22 AM
ozymaxwedge
Both of those pumps require a reg , they will run at about 12-14 psi you need about 7-8
ozymaxwedge is offline
Old 09-14-2007, 07:17 PM
bjuice
Administrator
bjuice's Avatar
Hey OZY..i would like to see more of your Mopar ?..
post some in the show off if you haven't already i will scroll over..
i am Chevy 1st...MOPAR 2ND.....Alawys been paretial to the Mopars since owning a 73 Doge Dart with a Canadian block 318 ..
red with white interior w/buckets and a white hockey stripe down the side..
Brian
Bjuice..
"I'M YOUR HUCKLEBERRY ! "
bjuice is offline
Old 09-15-2007, 11:30 AM
  #7
Racefab57
Im chevy also but, I LOVE THE OLDS MOPARS!!! can remember riding my bike down to webster chysler, plymouth to see the new mopps in the showroom (that was a lloooonnnnggg time ago. show us more!!!!! David.
Racefab57 is offline
