Woodsman track time
Well I took my hotrod to the track to see what it would run after we got it running and it has so many bugs that I did not get a good pass in but the best one was 60' 1.84 1/8 mile 7.25 @ 112mph well that is not at all what i thought it was going to run but have a lot of bugs to work out first before I get some good numbers out of it.
60' 1.84 = 1/4 13.24 @100.10
1/8 7.25 = 1/4 11.49 @ 115.32
1/8 112mph = 1/8 of 6.07
1/8 112mph = 1/4 9.62 @ 137.76
Wes,
It seems we all get hit with some type of gremlin with a new set up.
I know I have, Spib is going through it and probably several others.
I know your combo will see much better times.
You just need to get her dialed in and watch out :shock:
It will come around!!!!
Hey buddy it sounds like you are patting the pedal, because you don't know what will happen when you really get on it. I don't blame you, just make sure you are comfortable when you really nail it, sounds like an 8.50 down the road. Be carefully and do it right., you got womans and chillins to take care of.
Administrator
Wesley
This is a part of trying some thing new,there are always bugs,you just need to stay positive and work things threw,before you know it,you'll be grinnin from ear to ear,don't give up,you've got the hard part done now
Hope you have better times next time out,remember to buy some adult size depends,when you get it sorted,its going to be a rush :P
Good Luck Wesley
Good Luck Wesley
Originally Posted by topsportsman1
Wesley
Good Luck Wesley
Good Luck Wesley
DEPENDS.
#7
Tom its funny that you say that about the depends because when we all got to the track my brother gave me a nice sack as a present for getting the car running and in it was a depend. The trans cooler that I was using with my other set up that was fine before now leaks when I put it on the trans brake so got to get one with -an fittings to stop that. Zip you are so right I did not hammer on it because I was scared of it and did not know how it would react on the track. But it went down the track like you poped a string line on it. I have some other things to straighten out and then will be ready again. Spib dont have any more pic other then in showoff but did not even smoke the the tires at the track this time. Hope to have it lined out for next time and will get some to show off. Carl we will get there and its going to be a good feeling when we do.
#10
Steve my heart was beating about 300 beats a min until I staged the car and then it quite until I got to the other end and all was still in tacked.
Avery I think I will see a 8sec pass out of it after I get all the bugs out of it.
