Connecting rod ?
#7
OLIVER!
They dont mind Charing for there OVER PRICED SHIT!
I have a Nice set of Billet 6.635 BBC Rods,1830.00 with the Bolt Upgrade.I sell them CHEAP!
But,heres the Deal,6 are Useable and 2 are JUNK!After 2 Passes.1 of them let go of the Bearing for an Unknown Reason?They will Sell me two more though???
Later
G
Later
G
#9
Oliver makes a 6.635 rod that will easily handle that power level,we have several engines making over 2000 with that rod and no problems in 4 years . you will need to deck your block to get the correct deck height. we also use Crower billet rod for that application. H beam rods are not as good because the beam thickness doesn't give you enough side to side strength.Bill Bill
#10
I wouldnt buy oliver seems they like to break a lot.. Ive got pics to prove it !
Carrillo is a good rod, just make sure you get the good rod bolts and check the HP rating.
