Bolt on disc brakes
Anyone ever use one of those bolt on disc brake kits? I have a 70 nova that has drum brakes on the front and was wanting to switch it over. Car weighs 2820 without my big butt in it ...with me it weighs 3050 or a little less...depending on how many hot dogs I had that day.
Does anyone know of a kit that will work with the drum brake spindles?
I was thinking of using the Aerospace kit or the Wilwood. What other mods are needed as far as the master cylinder and proportioning valve etc?
Tod i am 100% certain aerospace makes a kit for rear drum brake conversions..i know i placed a set of them on my 65 nova with a dana 60 with drums...
i am not 100% sure...but i am almost sure that the spindle situation on the front you will need to change..i had a 69 camaro street car i had to change out 4 or 5 years ago..
Also beware that when you get the spindle set up right and place on the front disc brakes...your GONNA have to go with a Disc to Drum portional valve set up...i made the mistake thinking i could just bolt on front disc brakes to replace my drums and left the proportional valve alone and my rear brakes locked up in no time..
if you want to stay with your stock brake booster..i ordered a brake booster with a built in disc to drum proportional valve from a company out in California...if your interested i can try to run down this companys infor for you..they sell it all ( brake set up kits) for 55,57 chevys, 1st generation camaro's and nova's..
Brian
Brian
Bjuice..
"I'M YOUR HUCKLEBERRY ! "
Bjuice..
Brian
Brian
Thanks guys
This Nova site list a complete change over for $525.00 plus S/H.
http://www.nnnova.com/article_info.php?articles_id=13
