Trans brake what do you think
Old 01-25-2008, 08:45 AM
rsrsfishslayers
Default Trans brake what do you think
I am thinking of putting in a trans brake. What do you think. Is there good ones and bad ones. Are they easy put in. Where is a good place to find one its for my mustang.
Thank you
CPT.RON
rsrsfishslayers is offline
Old 01-25-2008, 04:07 PM
bjuice
Administrator
bjuice's Avatar
what kind of tranny ?
Bjuice..
"I'M YOUR HUCKLEBERRY ! "
bjuice is offline
Old 01-25-2008, 04:11 PM
shawnp
I think this guy could answer all your questions:
http://abruzzitransmissions.com/
shawnp is offline
Old 01-25-2008, 05:02 PM
rsrsfishslayers
It is a C-4 I think
Old 01-26-2008, 07:50 AM
bjuice
Administrator
bjuice's Avatar
well..the cost on these things ( Retail) go anyhwere from $400 ( tci) thru $620 ( jw)..plus shipping..its nothing more then a bolt in valve body.
Ron i do not know what you are planning on doing with your mustang...but IF YOU ARE NOT going to be seriously bracket racing it ,which to do this right you will need all the other electronics these guys are using to be competititve.
or running some heads up stuff where you must leave extremely hard,,which requires major updrages to drive line.
same for just getting out there and playing..a brake with require upgrades all the ay around on the drive line.
If your not going to pursue either of these options..i would leave the brake alone...
a brake on the street is No good..cause the car isn't gonna take the hit off the line from the brake...it will blow the tires off..
Many people use a brake to lock a car down in the beams..but if your motor/car is mild a good Line lock can be effective here footbraking the car..
if your dead set on putting a brake in the car..i can pm you a builders number locally that can sell you a quality brake cheaper then these retailers..
this is my take on the brake..lol..
Brian
Bjuice..
bjuice is offline
