1/8 mile gear
Old 02-10-2008, 04:29 PM
finley2005
APPRENTICE
Default 1/8 mile gear
i have a 74 vega with a 406 small block, BTE glide with 182 first gear. i have a 486 gear now which i was running a 1/4 mile. what gear will i need to run 1/8 mile? a 514 or lower? i am running14-32 slicks. thanks!!
finley2005 is offline
Old 02-10-2008, 04:53 PM
sg1586
Whats your finish line rpm in the 1/4???
sg1586 is offline
Old 02-10-2008, 07:42 PM
SPEEDNEEDS1
SENIOR BUILDER
A 5.43-or-5.57 would be great, and will mput you around 7000 at the stripe
SPEEDNEEDS1 is offline
Old 02-11-2008, 10:52 AM
aaaaaaaaaaaaa
486 is good enough and you aint gonna see much difference when you go to a 513 and i wouldnt ever go more than a 513 bcuz you would just be hurting your being consistent and it wont make it go faster ET wise
aaaaaaaaaaaaa is offline
Old 02-11-2008, 03:59 PM
shawnp
If you don't plan on running 1/4 mile at all, 5.13. If you still want to get down the 1/4 mile with the rods in the motor, stay with what you have. I have seen a lot of guys wanting to turn a 406 like it is a sb2 cup motor and throw a lot of gear at it. The end results are expensive and make the guy in the waterbox mad.
shawnp is offline
Old 02-20-2008, 03:57 AM
oncearacer52
We went from a 4.56 to a 5.14 and I was very surprised to pick up .250 with the exact same motor setup. We did not even pull the valve covers over the winter. I could run the quarter with the 4.56s but, no way with the 5.14s I shift at 6000 with a glide and cross the traps at 6550. 30 inch tires. One thing I forgot is I did make a ladder bar to go with the Slide-A-Link rear suspension and it did help the traction. So maybe that is where it is.
oncearacer52 is offline
