water in engine
Old 03-04-2008, 12:48 PM
zano
JUNIOR BUILDER
Default water in engine
i have a new engine ran about 30 minutes then put rest of car together i'm about to drive it for 1st time decided to change oil first in case of any shavings. it has been about 2 months since starting when i went to drain oil the first little bit as i was pulling plug looked and smelled like antifreeze but it was so little it would have not filled up a shot glass should i worry about this.the car is sitting back so this would be the very bottom of the oil pan thanks zano
zano is offline
Old 03-04-2008, 05:47 PM
GLADIATORINC
CRAFTSMAN
YES!! I destroyed a new big block chevy like this. My problem was a bad casted intake manifold. It had some pores on the gasket side and the antifreeze eventually made it through the intake gasket. Locked up the oil pump and kaboom! It will start as a drip then once the waterpump builds pressure it will blow. Check your intake gaskets. I dumped $5000 in the toilet.
GLADIATORINC is offline
Old 03-04-2008, 06:00 PM
bjuice
Administrator
bjuice's Avatar
intake and/or headgasket.
Bjuice..
"I'M YOUR HUCKLEBERRY ! "
bjuice is offline
Old 03-04-2008, 07:22 PM
a13badazztoys
APPRENTICE
isnt oil heavier then water ?? wouldnt the water/antifreeze be on top ??
just a question ??
a13badazztoys is offline
Old 03-04-2008, 10:22 PM
cepx111
just a question ??
No, water and or antifreeze is heavier than oil and will always be on the bottom near the drain plug, it's a dead give away thats something is leaking internally.
Goodluck, Charles
cepx111 is offline
Old 03-05-2008, 01:19 PM
itsabird
you may want to check, and make sure the bottom of the intake set,s flush against the cylinder heads.
itsabird is offline
Old 03-05-2008, 03:36 PM
  #7
zano
JUNIOR BUILDER
i filled it with water i'm putting 20 # of air on right know also i ran the electric water pump just came from the garage it's dripping oil from the pan once every 6 minutes. i'm hoping tomorrow morning it isn't dripping anymore. when i first got the engine i ran about 30 minutes when i turned it off checked intake bolts they were lose one wasn't even threaded in i hope that was the problem I' ll be praying tonight. thanks zano
zano is offline
Old 03-05-2008, 03:45 PM
  #8
itsabird
hope that does it. post result, and good luck.
itsabird is offline
Old 03-06-2008, 10:16 AM
  #9
zano
JUNIOR BUILDER
every 9 minutes now but it still looks like oil. i wonder how long it will drip if it's all oil
zano is offline
Old 03-06-2008, 11:54 AM
  #10
itsabird
let it drip into a glass container (clear), then wait and see if anything seperate,s out. water should be on the bottom, if indeed there is water.
itsabird is offline
