small block chevy
JOURNEYMAN
i have a 377 and just found out number 7 cylinder is dead no compression took it apart and can find nothing visully wrong can anybody tell me what to do next or if u have had this problem and what i need to do to fix it thanks guys
A leak down test could have told where the compression was going before you took it apart. With no compression at all, you probably have a valve that is bent or not seating. Try filling the #7 ports or combustion chamber with water or solvent and see if the valves hold....
I'd get that fixed, bolt the head back on and perform a leak down test to confirm that the rest is ok. Might be best to make sure your piston to valve clearance is good if the valve is bent.....
#7
it's hard to realize that (O) compression can not be seen if it's valves, they should be bent really bad.
Let us know what you found?
