vibration after torque converter install
Old 03-28-2008, 05:59 AM
rabiddawg
DYNO TECH
Default vibration after torque converter install
problem is a slight vibration @around 4200 that i think is the torque converter.
im thinking that maybe reclock the converter to the flexplate ?
you think that might help?
rabiddawg is offline
Old 03-28-2008, 06:09 PM
If it's possible, i would slide the trans back with the converter engaged to trans. enough to get an indicator up to the hub and check run-out while spinning the converter by hand, more than .002 it could be the problem. If there is no run out open up the flywheel hole 1/64" in case there is a bind.
Old 03-29-2008, 07:39 PM
bjuice
Administrator
bjuice's Avatar
do you have the converter shimmed up to the flex plate? if so how much?
Bjuice..
"I'M YOUR HUCKLEBERRY ! "
bjuice is offline
Old 03-31-2008, 08:16 AM
rabiddawg
DYNO TECH
didnt need shims
but I think the vibes are from a bad/wrong balancer.
still vibrates with converter disconnected
Old 03-31-2008, 08:09 PM
jmarksdragster
jmarksdragster's Avatar
What engine?
jmarksdragster is offline
Old 04-01-2008, 05:50 AM
rabiddawg
DYNO TECH
406 smallblock
Old 04-01-2008, 11:00 AM
  #7
johnracer
Is it internally or externally balanced? Stock 400 is external but the trend is to internal balance them for hp use. Flexplate and dampner are different depending on which way which way it's balanced....
johnracer is offline
Old 04-01-2008, 12:08 PM
  #8
rabiddawg
DYNO TECH
its extrenally balanced for sure
Old 04-01-2008, 12:40 PM
  #9
jmarksdragster
If you are using stock or stock replacement pistons , rods and crank you need the balancer and flexplate/flywheel for a 400. If any have been replaced with aftermarket parts the weight changes and the assembly needs to be balanced.
Old 04-01-2008, 07:23 PM
  #10
olds48
How much shim is acceptable?I'm running 1/4" ops: Both converters I've run needed same amount.Seems like alot to me.Half tempted to order next converter setup for a mid-plate just to take up the slack
olds48 is offline
