CARBURETOR WEDGE
JUNIOR BUILDER
What do you guys think about taking a phenolic carb spacer and milling an angle on it to make the carburetor sit level.Will it mess with any tuning or the way it runs,and should the carb be perfectly level? Thanks
I dont know about a dominator wedge, but it was common. and in most cases necessary down here to run all kind of wedges on the gas motors because of the angle the way they sat in the trawl boats. Try a marine supply, should have them in an assortment of thicknesses. Good Luck.
