CSR electric water pump vs Stock ref: temp
Old 07-17-2008, 04:38 PM
dynaguy03
Default CSR electric water pump vs Stock ref: temp
Does anyone have any info if switching from a stock water to electric will reduce coolant temps?.. If so what kind of temp diff might there be. If none maybe i will stay with a alum stock style pump.
Application is SBC with Alum heads..
thanks in advance
Keith
dynaguy03 is offline
Old 07-17-2008, 05:40 PM
lanham
Default temp
Dont't know if there will be a temp. drop but you can cool it down quicker between rounds.
lanham is offline
Old 07-17-2008, 07:26 PM
signsbyesa
not only will it cool down quicker it will relieve a few horses from
the crank, they just tested a 355 sbc on horsepower tv and i was
amazed it was like 10 horses, just the water pump, thats an
easy 10 to pick up, and bigger and longer headers for some
quick horsies, good luck :wink:
signsbyesa is offline
Old 07-18-2008, 07:28 PM
TheRabbit
TheRabbit's Avatar
big advantage is you can leave it running while the motor is off and save on the $12 gal racing fuel!!! i run mine on a temp switch so i don't have to baby sit while it cools or worry about killing the battery if i get to running my mouth and forget the fan and water pump are still running.
TheRabbit is offline
Old 07-19-2008, 02:19 AM
dynaguy03
Thanks Gents.. like always great real world responses... Rabbit..i wired it up already.. but i better watch if i start yappin i dont wipe out the battery.. now im thinking of redo.. with a temp switch!
