Fuel pressure problem
Old 08-04-2008, 07:15 PM
mopar1968
mopar1968's Avatar
Default Fuel pressure problem
:? Ok to start this, fuel pressure is running at 15 psi on pressure gauge, would not adjust down, replaced regulator with holley regulator, ran couple times, guess what 15 psi again, ordered a billet regulator from Ron Owens installed guess what ? you guessed it 15 psi again, i have adjustment screw all the way down flush with top of regulator to get 7 1/2 pounds. Any answer's to what may be going on? plugged filter? bad pump?
mopar1968 is offline
Old 08-04-2008, 07:26 PM
Gage, not right, if the carbs are not leaking by i doubt if you really have have 15psi to the carb. I'm not a carb person, totally injection, so i could be way off o this one.
Old 08-04-2008, 07:47 PM
hammertime
1st thing I'd do is replace the gauge.
hammertime is offline
Old 08-05-2008, 10:53 AM
Scooterz
Mopar: I have replaced 3 Holley reg's in 6 months... one of which had a good diaphram, but was allowing fuel by it from faulty machining... causing fluctuating fuel pressure. I have one guage on the dual feed, & another liquid filled unit separately now so I can check them against each other to make sure the pressure is right.
Scooterz is offline
Old 08-05-2008, 01:48 PM
mopar1968
mopar1968's Avatar
:? I have allready replaced the gauge with a liquid filled one, three regulator's later still high pressure, no fuel flowing in carb, needles holding properly. :?: :?: By the way the gauge is mounted to one side of regulator and line to carb on other side of regulator :!: :!:
Old 08-05-2008, 03:02 PM
hammertime
Which fuel pump do you have ?
Old 08-05-2008, 05:41 PM
  #7
mopar1968
mopar1968's Avatar
holley blue pump.
Old 08-05-2008, 07:42 PM
  #8
Scooterz
You don't have a return right? Man.... that does not make sence... I can see why you are stumped right now. I wonder if a air is entering into the fuel system somehow...
Scooterz is offline
Old 08-05-2008, 07:43 PM
  #9
mopar1968
mopar1968's Avatar
Right no return. I would love to go to fuel injection but know nothing about it.
Old 08-05-2008, 07:46 PM
  #10
Scooterz
Amen to that... same here. The Holley blue... is it maxed at 15psi/output?? or can it produce more?
Scooterz is offline
