goodyear slicks
APPRENTICE
info needed been haveing trouble planting right rear tire race last night 60 foot was up and down seen today my tires dots are gone from middle to in side the rest is abought 50% worst on right side could houseing be bent has fab 9inche ? or
JUNIOR BUILDER
Have someone video your car making a pass. You can slow down the video while you watch it and that should help you find your problem. I bet your rearend is not square with the chassis like the guy above mentioned.
You said dot tires. Do you drive this car on the street? If so, and you have a spool, everytime you turn one tire must slip, even if your turning slow. And while your turning your car is applying more weight to the outside.
