66 mustang motor mounts
APPRENTICE
it was a 6 cyl 3 speed and changing to a 87' 302 and a 4 speed what motor mount are right for the swap i seen different ones one line but i what to make sure i get the right ones and i'm sure one of you have done this thanks
Use motor mounts for the '66 mustang 289. You will need to swap the oil pan and pick up tube out on the '87 motor to the older style front sump pan. The '87 has the rear (what a lot of people refer to as the double) sump pan. It won't clear the steering linkage.
