blower ?
10-25-2008, 08:10 PM
blower ?
i need to know the torque spec. on a 6-71 bds street blower.thank for any help,john
10-26-2008, 01:24 PM
torque what? The aluminum studs,bolts,timing gear bolts or what?
10-26-2008, 05:41 PM
sorry
ops: ,the stud that bolt the blower to the intake
10-26-2008, 06:43 PM
Install the bolts into the maniflod useing anti-sez by hand, then set the blower on the maniflod with gaskets, torque nuts useing flat washers to 25 ft.lbs. with anti-sez also working from ctr. out useing criss/cross patern.
Hope this helps.
10-26-2008, 07:14 PM
wieand 8-71 is only 12 lbs........25lbs might be to much...
10-26-2008, 07:40 PM
Haha, my last two blown motors i have used steel 7/16 bolts!
