oliver or bill miller rods
Old 10-30-2008, 06:11 AM
michael1
Default oliver or bill miller rods
Which rods should I use in a 632? It will be used to drive about 2 miles on the street to cruise nights 2 times a month and race at the track maybe 7 times in a year. The car will be mostly a show car but it will still have about 1200 hp on motor. If I use oliver rods I will use diamond pistons and if I use bill miller I will use his pistons. I had the car two years and I only put about 400 miles on it and 300 of that was in the first month.
michael1 is offline
Old 10-30-2008, 07:16 AM
jmarksdragster
jmarksdragster's Avatar
Unless you plan to run extreme RPM's stick with steel. Oliver, Carillo, Crower, any would work.
jmarksdragster is offline
Old 10-30-2008, 07:21 AM
michael1
About 7000-7300 rpms. Bill Miller says that the aluminum is actually stronger but I would expect them to say that. If I get everything from Bill they said it would be about $2400.
michael1 is offline
Old 10-30-2008, 09:52 AM
ARUSSELL
Both a high quality steel and aluminum rod will work but the aluminum is more insurance
ARUSSELL is offline
Old 10-30-2008, 09:53 AM
hammertime
X2 all my td/ts buddies replaced alum rods every winter, some before that. Which seems to be common thing with alum rods. A steel rod you dont worry about that.
hammertime is offline
Old 10-30-2008, 10:50 AM
bbchevy
Default Rods
I'd BUY a EAGLE before the OVER PRICED JUNK THat OLIVER SELLS!!!!!
I have 2-New Billet Olivers Here to Prove what i'm Saying!!!!
Later
G 8)
bbchevy is offline
Old 10-30-2008, 12:17 PM
  #7
OneBadGMC
Default Re: Rods
Later
G 8)
Oh Gawd... Here we go again.
OneBadGMC is offline
Old 10-30-2008, 02:01 PM
  #8
jmarksdragster
I have Oliver's in my SB2 and no issues, the only thing I would recommend is to upgrade the bolts on any of the brands. Getting ready to order a set for a 460ci small block with SB2 heads. Should be $1300 plus the bolt upgrade for big block Oliver's.
Old 10-30-2008, 04:12 PM
  #9
gungho
bbchevy-----lets see some pics.
gungho is offline
Old 10-30-2008, 04:25 PM
  #10
kwkracing
bme or brooks aluminum rods no problem
kwkracing is offline
