what trany do I have
Old 01-11-2009, 08:41 AM
chpseat987
CRAFTSMAN
Default what trany do I have
Ok if you read the scammer board you can see I really got screwed over but I am trying go get passed that and move on, I was told that the car I have a 72 nova, has a turbo 400 with reveres shift with a full manual shift and it does, and a trany brake it does, but how do I tell the differance if I have a 350 or in fact it is a 400 trans? :?: :?: thank you for reading and any reply's
chpseat987 is offline
Old 01-11-2009, 08:45 AM
TopspeedLowet
The tail shaft is larger on a th400 and the case is bulkier. and the pan gasket is not square with the corner cut off like a 350
TopspeedLowet is offline
Old 01-11-2009, 08:58 AM
chpseat987
CRAFTSMAN
Are ther any type of casting numbers I can look for?
Old 01-11-2009, 09:10 AM
krazy55ken
APPRENTICE
Default tranny
On the 350 it will have the transbrake Soleniod on the back side of it. On the 400 it will be on the passenger side.. Hope this helps.. KRAZYKEN
krazy55ken is offline
Old 01-11-2009, 11:48 AM
slowmotion
From TCI's site. Which one looks like yours?
TH350 pan
TH400 pan
Powerglide pan
slowmotion is offline
Old 01-12-2009, 02:56 AM
chpseat987
CRAFTSMAN
Wow great stuff Thank you the trenny brake is on the pass side. I have a reular pan do you recomend a fin pan for cooling?
Old 01-12-2009, 04:02 AM
  #7
TopspeedLowet
No I don't, Most of your cooling will be done by a trans cooler when running. Fins are better than no fins, and cast aluminum isn't as good at transfering heat as a sheet metal aluminum is. Steel is just fine as well. I focus on the cooler for cooling. The larger the pan the greater the heat sink. The larger the cooler the better the cooling ability.
Old 01-12-2009, 09:18 AM
  #8
Tod74
the deeper pan will hold more fluid so that alone will help with the heat.
I use the heavy cast aluminum pan on my glide ..it helps to stiffen up the case..at least I think so.
Tod74 is offline
Old 01-12-2009, 10:29 AM
  #9
desoto30
JUNIOR BUILDER
How does the deeper pan help with the heat?
desoto30 is offline
Old 01-12-2009, 03:22 PM
  #10
TopspeedLowet
Well, the more oil that you have in the system, the more heat that it will take to raise the temp.
