How much is too much boring a 350...
I have a early 70's 350 block that has been bored .080 and a set of trw dome pistons that match it. My question is do you guys think this will be all right in a bracket car?
I am getting ready to build a new motor for my dragster and I have this sitting around, I was thinking about putting a 3.75 stroke crank in this and letting it rip.
What do you guys think???
Thanks Guys
Thanks Guys
throw it together some of my best engines were built from parts like that just dont use the old oil pump sitting under the workbench!
loose is fast! what do you have to lose? if you dont I might..
#7
Thanks Guys
Thanks Guys
#8
Josh i had similiar concerns and questions when i ran a 512 series 454 block at .125 over..with a 4.25 stroke crank it was a 511 or 512 for some if you round up .
Anyhow i was told by many people that this was too much Bore and it would run hot and most likley not hold up..then i had some say it would be ok..
i ran it and it done fine..ran at 185 degree's..it was PERFECT !.....a very strong engine..of course i did not spray any Nos and my compression was around the 13:1 mark
i think the only way to know for sure how much meat is left in those cylinder walls is to sonic test them and just see...and then your still gonna have people who think it may or may not work..
At a minimum i would sonic test Block being that it is so old..it may have some spots that are just too risky to try..
Of course the lil "m' Block is the best Route but its also a lot more Money..
if you can handle the Money side of it i would say upgrade Now,,cause i honestly believe your gonna end up there in the end..the same thing with me..i went back With Big "m" Block this last go around.
just my take on it.
Brian
just my take on it.
Brian
Bjuice..
"I'M YOUR HUCKLEBERRY ! "
Bjuice..
#9
Thanks for all your info guys. I was just thinking about throwing this together on the cheap to have as a spare or use in my footbrake truck.
I got this stuff in a deal and nobody wants to buy it, so I thought maybe I could throw it together.
It sound like it should work for what I want.
Thanks Again!!
Thanks Again!!
#10
One more time. Not to stir any pot. But consider this. if the engine is .060 now, with no troubles, going .080 is only making the cylinders .010 thinner in any one spot. With block filler to the bottom of the water pump, I wouldn;t worry about it. Is it ideal? No. Will it work for a budget deal? Yes.
