355 circle track engine problems
Old 04-01-2009, 03:05 PM
dgordner
JUNIOR BUILDER
Default 355 circle track engine problems
I race a 355 chevy circle track pro stock. I rebuilt the engine at the beginning of the race season. The first time out we finished 6th with the car and no problems. The next three times we had to load her up and bring her home before the feature. My son tells me that if he just eases into the throttle the engine seems fine but if he floors it the engine seems to vibrate like an asphalt roller with the drums on vibrate. I can't distinquish if it is electrical or fuel. We have replaced distributor and all components, coil, wires, carb. Compression is 150 therabouts. Any ideas???
dgordner is offline
Old 04-01-2009, 03:30 PM
dparker
Have you checked the universal joints.
dparker is offline
Old 04-01-2009, 03:44 PM
dgordner
JUNIOR BUILDER
Yep. It is not in the driveline. It is in the engine as we are in the way!!!!
dgordner is offline
Old 04-01-2009, 03:53 PM
dparker
When you rebuilt the engine did you change the crank or any internals.
dparker is offline
Old 04-01-2009, 04:23 PM
dgordner
JUNIOR BUILDER
Not the crank. New eagle rods and Ross pistons. All ballanced. The engine worked like a top the first race. The only thing I changed from the first race to the next was the battery. Since then I have changes all the cables as well.
dgordner is offline
Old 04-01-2009, 04:30 PM
MEMRACING62
VALVE LASH?
MEMRACING62 is offline
Old 04-01-2009, 04:44 PM
  #7
dgordner
JUNIOR BUILDER
The first week we ran it at 14 and 16. I have had it at 18 and 20. No difference.
dgordner is offline
Old 04-01-2009, 04:53 PM
  #8
lookingaround
my truck done something close to that. felt ok driving but when you put a load on it it shook like crazy. come to find out the bellhousing was broke almost all the way off. not saying this is your problem but thats how mine acted
lookingaround is offline
Old 04-01-2009, 04:58 PM
  #9
dgordner
JUNIOR BUILDER
Nope!! I nut and bolt the car before every race. I am a safety nut!!! I do not rely on anyone but me to find those kind of problems. I don't want my son hurt so I am a fanatic. Seeing your transmission reminded me of the one I discintegrated on the quarter mile in Pa. I broke it so bad I didn't need to unbolt it to remove it!!! COSTLY
dgordner is offline
Old 04-01-2009, 05:42 PM
  #10
TheYellaBrick
TheYellaBrick's Avatar
dirt or asphalt ?
manual or auto?
Is there any vibration with engine at idle when the car is NOT moving?
Have you eliminated any sort of electrical miss ? plugs / wires / dist cap
Is there vibration when the engine is revved up when car is not moving ?
If vibration is present ONLY with car in motion,
- at what speed,
- under load,
- gliding with clutch in or in neutral ?
TheYellaBrick is offline
