How do you tell glide tailshaft
Old 04-02-2009, 08:16 AM
slickfuel
CRAFTSMAN
Default How do you tell glide tailshaft
How do you guys tell if your tailshaft on your aftermarket
cased power glide is rollerized or not ??????
Thanks
Vic
slickfuel is offline
Old 04-03-2009, 10:37 AM
ML3885
it has a roller bearing in it
ML3885 is offline
Old 04-03-2009, 11:26 AM
Pull the tailshaft housing off this will shed some light on the roller bearing (note you have to have a different yoke for a rollerized tail housing)for sure and you may be able to tell if it's an after market tail shaft some are marked. I know the 1.82 tail shafts have a counter bore rather than a center in them, also the stock tail shaft are usually black, which means they we machined after heat treating and most after market show a brighter finish on the machining. None of this is fool proof though. Don't always trust the stampings on the end of the rtail shaft, there was an article/thread on here a few months ago where a person bought a supposedly built to the hilt transmission, and the tail shaft was stamped, when he took it apart it was totally stock, meaning somebody scammed someone by stamping #'s on the tail shaft.
Old 04-03-2009, 11:37 AM
slickfuel
CRAFTSMAN
Thanks guys,..its a Ried tail shaft,
and a stock yoke fits in it, I know the rollerized yokes are a little smaller diameter than a stock yoke, I just wanted to be sure.
Looksa like I need to really make sure now, and hopefully I havent F`d
it up,..lol..
thanks
Vic
Old 04-03-2009, 07:16 PM
Tod74
Tod74 is offline
Old 04-03-2009, 08:09 PM
slickfuel
CRAFTSMAN
If it is a rollerized bearing tail shaft, then why does a stock yoke
fit in it ????
The stock yoke is sappose to be a few thou larger diameter and you would have to physically force a stock yoke into a rollerized tail housing
Right ???
Thanks
Vic
Old 04-03-2009, 08:25 PM
  #7
HUH :?: :?: Are you saying it's rollerized and a stock yoke fits :?:
I'm lost
Old 04-03-2009, 08:31 PM
  #8
slickfuel
CRAFTSMAN
Yeppper,
...thats why I asked the original question.
It didnt make any sense to me because I was tolled it was rollerized, but yet a stock yoke fit in it .
I will just pull it apart and check, maybe its a bushing in there.
but thanks
Old 04-05-2009, 06:18 AM
  #9
ML3885
chevrolet made two different diameter trans yokes for glides and 350 turbos, one will work with a roller tail housing, because i have it in my car.hope this helps.
ML3885 is offline
Old 04-05-2009, 07:46 AM
  #10
slickfuel
CRAFTSMAN
4Mark,..thanks for the input,..
I do not have a rollerized yoke to measure,.
can someone measure the diameter of one for me ????
Thanks
Vic
