Acceptable offset between crank/trans input shaft
Old 06-11-2009, 07:28 PM
kicker91laser
Default Acceptable offset between crank/trans input shaft
With all of the adapter bellhousings and plates, it seems that the crank and input shaft on the trans may not be perfectly centered with each other. That being said, what is an acceptable amount of offset between the two? If it matters, this would apply to th350/400 trans.
kicker91laser is offline
Old 06-11-2009, 08:39 PM
I don't know what the acceptable amount is but i can guarentee you if you have as much as .005 you will have a front seal leak very quickly after the trans is installed.
Old 06-12-2009, 12:19 PM
kicker91laser
Thanks zip, is it an acceptable practice to use offset dowel pins with the auto trans?
Old 06-12-2009, 01:03 PM
TopspeedLowet
The dowels are to compensate for an ALIGN BORE job on the mains that moves the crank up toward the camshaft. No offset is "normal" any thing else is off.
Bruce
TopspeedLowet is offline
Old 06-17-2009, 04:40 AM
chevyfireball
Wouldn't even go there bud. You're asking for trouble.
chevyfireball is offline
