Spindle Mount Tire Balance
Old 06-21-2009, 06:24 PM
kbartley
Default Spindle Mount Tire Balance
How do you balance youre wheel's that are spindle mount? Motorcycle shop????
Kris
kbartley is offline
Old 06-21-2009, 07:00 PM
bbchevy
Default Re: Spindle Mount Tire Balance
Kris
Kris,
Just Unbolt the center and put them up on the Balancer!
Thats the Way,we always did OURS........?
Later
G 8)
bbchevy is offline
Old 06-22-2009, 06:48 AM
TopspeedLowet
You have to go to a motorcycle shop or one that has a balancer for motorcycle tires. The spindle mount rims are the same as bikes. I would not recommend rigging a standard balancer to do them. Go to a Harley shop and you are more likely to get competent work.
Bruce
TopspeedLowet is offline
Old 06-30-2009, 08:13 AM
kbartley
Default balancer
I have a set of Halibrand Mag. wheel's on early ford spindles which center hole is too small for a regular balancer. So I will try the harley shop.
Thank's
Kris
kbartley is offline
