sbc H.P. gain with SHP Block
Ok what do you guys think if I change my current stock 350 oem block with this combo,383,13-1,.558 int,.550 ex,260,[email protected] comp flat tappet,stock 215 Dart Iron Eagle Platinums,Manley 6 inch rods,Super Victor port matched,750 APD Alky carb, in my 3100 lb 68 camaro,to a Dart SHP .030 block with 14-1 Mahle pistons,block from CNC Carl,and use the same heads,cam,crank,intake,will I see any power increase?
A block isnt going to just gain you hp ? actually I think this block is more weight then your stock so you'd slow down there, the one point of comp I have found is worth slim to none on mine.
Joe Sherman posted on speeedtalk that going from a 400 block to World block was a 30 horse gain over a stock block do a search on the site or PM him.
