fuel pressure bouncing
Old 07-06-2009, 12:28 PM
chevyart
Default fuel pressure bouncing
friends car has fuel pressure bouncing from 2-7 lbs. have new fuel pump, lines are ok, fuel filter is new. car runs ok till you give it gas and then it dies down. have new guage also. is it possible that the needle and seat is sticking and making the pressure jump up and down. if this is a possibility, haw can i verify it, short of changing the needle and seat. thanks chevy art. any other ideas
chevyart is offline
Old 07-06-2009, 04:41 PM
johnracer
Most likely some other problem. Fuel line too small maybe, or restriction in the tank........what kind of pump?
johnracer is offline
Old 07-07-2009, 12:27 PM
chevyart
hey johnracer. pump is ok. is a berand new holley black pump. we are going after the tank right now. you are probably right on. its the only thing it couyld be thanks chewvy art
chevyart is offline
Old 07-08-2009, 09:38 AM
dparker
I would say its a bad regulator, spring weak.....
dparker is offline
Old 07-08-2009, 02:46 PM
TheRabbit
TheRabbit's Avatar
If it sticks at 2- 7 I would double check the guage. They stick even when new. If it really is bouncing between 2 and 7 very lickley regulator. Don't care who's pump or regulator you use ALL ARE OVERPRICED and break way to often. I always keep an extra pump on hand.
TheRabbit is offline
Old 07-08-2009, 03:34 PM
Scooterz
Holley Black says they are "internally regulated" while the Blue calls for a remote regulator. Just FYI.... Scooter
Scooterz is offline
Old 07-12-2009, 08:47 PM
  #7
russ67chevelle
ive heard the liquid in the diffrent liquid filled gages can cause unaccurate readings from engine heat...i had one then ditched for a better,non filled fuel gage. good luck
russ67chevelle is offline
