TOOTHACHE!!!
Old 09-02-2009, 04:53 PM
lively
lively's Avatar
Default TOOTHACHE!!!
How much nitrous can be used on a "pump gas" engine? 200? 300? ?????400 :x :x
THANKS GUYS, LIVELY
lively is offline
Old 09-02-2009, 05:30 PM
bjuice
Administrator
bjuice's Avatar
Dennis are you asking how Much NOS can be run on 92 octane fuel or How much NOS can be Run thru a Pump gas (low compression) Motor using High octane Racing Fuel ?
bjuice is offline
Old 09-02-2009, 05:55 PM
DirkaDirka
DirkaDirka's Avatar
:shock: :shock: Thats my name too!!! :shock: :shock:
DirkaDirka is offline
Old 09-02-2009, 06:48 PM
chrisr
Just keep adding until it blows up, rebuild it and pill it down a hair from where it blew at and you'll be fine. :lol: :lol: :lol: :lol:
chrisr is offline
Old 09-02-2009, 07:25 PM
lively
lively's Avatar
92 octane 8)
lively is offline
Old 09-02-2009, 07:56 PM
bjuice
Administrator
bjuice's Avatar
not a lot...i think Nos phamplet says up to 100hp NOS on 93 octane...then from there they suggest the better gas...
you would still need to back out about 4 degrees of timing to be safe at 100 shot with 93 octane
it would also depend where your static compression is...example: 7:1 can probaly handle a little more than a 10:1 static compression motor....and both engines are Pump gas...one is just on the low end while the other is on the higher end.
Bjuice..
"I'M YOUR HUCKLEBERRY ! "
bjuice is offline
Old 09-03-2009, 06:28 AM
  #7
TheRabbit
TheRabbit's Avatar
Spoken from a true drag racer!!!!!! LOL!!
TheRabbit is offline
Old 09-03-2009, 10:36 AM
  #8
Tod74
That sounds like how I do stuff....lmao
Tod74 is offline
Old 09-03-2009, 12:04 PM
  #9
ARUSSELL
I think your wallet will ache more then your tooth!!!!
ARUSSELL is offline
Old 09-03-2009, 06:53 PM
  #10
wrightway
SENIOR BUILDER
Default Re: TOOTHACHE!!!
THANKS GUYS, LIVELY
How often you plan to spray it may by something to consider also
I have sprayed 150 on 92 pump maybe 8-10 times over a 5yr period
On my 11.5:1 406 runs 10:30s on 92 9:70 on 150/92
Pulled the motor down twice over the 5yr’s just to check the bearings
And they looked great so back together it went
wrightway is offline
