powerglide no reverse(rossler trans with brake)
fresh trans but has been on shelf for years, apears to have only have high?? gear no reverse or low, wont back up even holding trans brake button, what should i ck?? Thank,s Tim
I would call Carl 1st. If you open it, then you are going to void any help you might get from him (and good luck with that). If I wanted to get it fixed right, then I would use the only trans guys in NE Ohio in either Dion Vickers or Marco Aburzzi.
