maximum rpms?
Old 10-10-2009, 02:55 PM
z28camaro82z
Default maximum rpms?
I have a small block 400 i been told was bored .030 over. i'm really not sure, but to be safe, i'm going to assume the bottom end is stock. the heads are world sportsman II 200cc heads, the intake is a torker II, which i'll probly be swapping for a performer rpm. i don't know much about the cam either, i wasn't given a cam card, but through motors i've had and built in the past, i can make a rough estimate that the duration is in the 280 ballpark, and probly somehwere around a 500 lift. i checked the timing at idle, and it is 11 degrees advanced. my question is where is the safe range for maximum rpms? i want to set a rev limiter, but don't know where to set it at. the motor makes power past 5,000 rpms, but i don't want to push it too far without some advice or guidance from someone who knows this kinda information a little better.
z28camaro82z is offline
Old 10-10-2009, 04:02 PM
bbchevy
Default 400
With the STOCK Lower End,I would say Keep it in the 5500 Rangs.
Later
G 8)
If You could Give More Info?You would get More HELP!
bbchevy is offline
Old 10-10-2009, 04:52 PM
Tod74
Default Re: maximum rpms?
I had a stock bottom end 406 that I took to 6000 all the time....They have shorter rods than the other SBC 5.565 (I think) vs 5.7.
Tod74 is offline
Old 10-10-2009, 06:30 PM
fbodyjunkie
JOURNEYMAN
I had a 400 .060 over that had a stock lower end that I turned 6500 every chance I had to race. Had a buddy that had 1 that for $20 would bury the tach needle to 8000 rpm's. He never blew it up. And I was always told they wouldn't live past 6000
fbodyjunkie is offline
Old 10-11-2009, 08:03 AM
z28camaro82z
thanks for the help gentlemen, i will most likely drop the oil pan to inspect the rod bolts, and set the rev limiter to 6k, and maybe i'll experiment with 6500 before making my final decision.
Old 10-11-2009, 12:03 PM
oldandtired
oldandtired's Avatar
Is this your engine plus your buddies engine? Or did he bury the needle driving your engine? Something does'nt add up...
Dave
oldandtired is offline
Old 10-11-2009, 12:17 PM
  #7
MEMRACING62
8000 RPM :shock: STOCK BOTTOM=BOOM :!: :!:
MEMRACING62 is offline
Old 10-11-2009, 01:34 PM
  #8
fbodyjunkie
JOURNEYMAN
I guess I didn't make it clear. My buddy had 1 also. I never would let someone else race my junk. Mine was balanced with stock crank and rods, with Venolia pistons.
Old 10-13-2009, 04:19 AM
  #9
JEFF69Z28
I SPIN MINE(406CID) TO 7200 EVERY WEEKEND AND HAVE NOT HAD ANY ISSUES,BUT MY BOTTOM END IS NOT STOCK.IF I WAS TO GUESS I WOULDNT GO ABOVE 6500....
JEFF69Z28 is offline
Old 10-13-2009, 11:29 PM
  #10
cepx111
lol, he said race and junk 8)
I'm thinking 6500 tops.
cepx111 is offline
