dam pooch
Old 11-02-2009, 08:19 AM
corey454
APPRENTICE
Default dam pooch
ok folks turnin to you for help i have a 396 30over 10.25 compression in a 2700 lb car with a 4500 converter and a glide with a 586 gear car runs on e85 runs ok starts good crack the throttle and its there take it to the track put it under a load and wata pooch just wont rpm at all throw me some ideas here or email [email protected]
corey454 is offline
Old 11-02-2009, 10:40 AM
hammertime
what msd box and coil ?
hammertime is offline
Old 11-02-2009, 02:10 PM
corey454
APPRENTICE
Default pooch
6al box (chip removed) msd coil msd distributor timing at 40 locked out
corey454 is offline
Old 11-02-2009, 04:21 PM
TS1955
Is this combo new or have you ran it before?
TS1955
TS1955 is offline
Old 11-02-2009, 04:56 PM
corey454
APPRENTICE
Default pooch
came on the car when i got it but all seems to work ok
corey454 is offline
Old 11-02-2009, 05:49 PM
THERATTLER
THERATTLER's Avatar
you said runs on e85,,,what kind of induction?
THERATTLER is offline
Old 11-03-2009, 12:53 PM
  #7
corey454
APPRENTICE
Default pooch
800 cfm converted carb strip dominator intake
corey454 is offline
Old 11-04-2009, 01:51 PM
  #8
THERATTLER
THERATTLER's Avatar
sorry , don't know alot about carbs , on injection when mine won't rpm , it is usually a little fat on the fuel mixture,,,mayby somebody else has a little experiance with the e85 carbs
Old 11-04-2009, 09:20 PM
  #9
cepx111
When you say it wont 'RPM' are you refering to a stall or a bog off the line.
Any popping or mis-firing?
Are you getting full throttle?
How about the spark plugs, are they new or old? What are they gapped at?
More info please.
cepx111 is offline
Old 11-05-2009, 06:23 AM
  #10
JEFF69Z28
CHECK AND MAKE SURE THE CARB IS OPENING ALL THE WAY WHEN YOU FLOOR IT.
JEFF69Z28 is offline
