quess the hp/send your opinion ...getting dynoed 11-11-09
Old 11-10-2009, 07:09 PM
bixblk
bixblk's Avatar
Default quess the hp/send your opinion ...getting dynoed 11-11-09
SEND YOUR OPINION
I JUST PUT A 496 BBC TOGETHER
SPECS AR FOLLOWS:
TEAM MAGNUSON BBC
496 CI (4.25 STROKE. 4.310 BORE)
SHORT BLOCK AS FOLLOWS:
GM BLOCK
SCAT CRANK
EAGLE H RODS 6.385
SRP PISTONS W/43 CC DOMES
12.65 TO 1 COMPRESSION
VALVE TRAIN
BULLET ROLLER DEGREED @108
.714 LIFT INT AND EXH
300 DEGREES ADVERTISED DURATION INTAKE
310 EXH
ACTUAL LIFT .695 AT VALVE (PLUS 18 LASH )=.713
COMP ROLLER LIFTERS
COMP GIRDLE
COMP ROCKERS 1.7
VALVE SETS AT 18 COLD 22 HOT
SINGLE DOMINATOR 1050
DART PRO 1 OUT OF BOX
2.30 INT
1.88 EXH
COYLES TIMING GEAR W/ TORRINGTON BEARING AND COVER (ADJ)
QUESS THE HP ?????????
NO CHEATING DO NOT USE THE HP CALCULATORS
I HAVE FOUND THEM TO BE PRETTY CLOSE
LET ME KNOW JEFF
bixblk is offline
Old 11-10-2009, 07:13 PM
DirkaDirka
DirkaDirka's Avatar
I am just guessing and saying 600ish hp maybe???
DirkaDirka is offline
Old 11-10-2009, 07:15 PM
bixblk
bixblk's Avatar
Default REPLY TO DIRKA QUESS
PRETTY SURE IT WILL BE MORE THAN THAT
bixblk is offline
Old 11-10-2009, 07:51 PM
DirkaDirka
DirkaDirka's Avatar
Im still learning everything about those there race motors.
Old 11-10-2009, 07:57 PM
bixblk
bixblk's Avatar
I'M WITH YA
600 ISH AT THE WHEELS ?????? WOULD BE NICE
THIS IS PRETTY COMON COMBO, BUT THIS ONE SOUNDS GUTSZY
bixblk is offline
Old 11-10-2009, 08:15 PM
bixblk
bixblk's Avatar
ANOTHER TIP
I THINK THESE HEADS MAYBE A LITTLE TOO BIG FOR JUST A 496 INCH MOTOR
BUT MAYBE A 250 SHOT WOULD WAKE THESE HEADS UP AND GET THEM WORKING A LITTLE BETTER
CANNOT GIVE AWAY SECRETS, BUT THIS MOTOR WILL NOT BE RAN AT THE TRACK TILL 2010.
WE WILL SEE
bixblk is offline
Old 11-10-2009, 09:43 PM
  #7
You didn't say what manifold, i don't think the heads are too big, if you have a 454R intake and 2 1/8"/2 1/4" headers, we're pushing close to 750Hp with a pump gas 468" with Brodix 2 extra heads.
I'm guessing real close to 800 HP. with right tuning, maybe a little more. I'm buliding a 496" for a customer with Dart 308's steel heads and stacks injection, i'm looking to go more than 800 HP with it.
Old 11-10-2009, 11:12 PM
  #8
cepx111
825 HP +/- 25
cepx111 is offline
Old 11-10-2009, 11:14 PM
  #9
cepx111
LOL ~> Dennis
Maybe if it was a 3/4 cam corvette motor.
cepx111 is offline
Old 11-11-2009, 01:48 AM
  #10
fla1976
fla1976's Avatar
772 hp, 821 tq
fla1976 is offline
