condensation on plugs?
Old 12-02-2009, 05:30 PM
cam67152
Default condensation on plugs?
I just finished firing my BBC 496, ran great! set the timing checked all the usual thingsevery thing seemed fine till the next day, I pulled a plug and it looked like it had water on it, I retorqued the intake (which I had milled to fit) checked the oil for water, it was fine (drained and changed filter) Started it up ran fine, next day water on the plugs again? Presurized rad, no leak down. Is this condensation? or a bigger problem?
:? thanks for any advice in advance.
cam67152
cam67152 is offline
Old 12-02-2009, 05:43 PM
BEAST477
BEAST477's Avatar
It could be condensation. How long are you running it? Are you running it long enough to bring the oil and coolant temps up to 180-200 degrees, if not that can cause condensation. I've had it happen before when taking off valve covers to check lash.
BEAST477 is offline
Old 12-02-2009, 09:56 PM
cam67152
I did bring it up to temp in the morning to set timing. But started it up later that night for a short time. Should i try bring it up to temp, let it cool then check the plugs? Then check them them again the next day. By the way its on all the plugs.
CAM67152
cam67152 is offline
Old 12-02-2009, 11:25 PM
cepx111
Just curious what is the ambient air temp in your area?
Cool moisture ladden air will condensate on metal, especially this time of year.
It might be what your seeing.
Run the motor till you get it good and warm 180/200ish, let it cool till you can work on it without getting burned - then check the plugs.
That's what I do.
Cp
cepx111 is offline
Old 12-03-2009, 04:26 AM
itsabird
if all looks well... no water in the oil, not over heating, then i agree with cepx, cold weather condensation.
itsabird is offline
Old 12-03-2009, 04:34 AM
cam67152
I'll try that this afternoon. Temps have been quiet cool, just above freezing, and wet!
cam67152 is offline
Old 12-03-2009, 06:16 AM
  #7
TheYellaBrick
TheYellaBrick's Avatar
THIS will be the issue ! Let 'er get up to temp and I'll bet you'll NOT find H20 on those sparkers.
TheYellaBrick is offline
Old 12-03-2009, 08:33 AM
  #8
BEAST477
BEAST477's Avatar
Huh, I thought thats what I said, kinda. Now I'm confused.
BEAST477 is offline
Old 12-03-2009, 10:13 AM
  #9
itsabird
yes you did, about the valve cover condesation, i had a guy tell, that hanging light bulb, or shrouded shop light over the engine would cure the problem.
itsabird is offline
Old 12-03-2009, 01:08 PM
  #10
TheYellaBrick
Beast,
Us old guys kinda rererepeat stuff, dontchya know :shock:
:roll: ops: ops:
