Darts new SHP block
Originally Posted by rdy2fly
I have one of these blocks on back order. I am a worried about the 350 journals in a stroker application. I will be doing a 434, if I ever get my block.
Warren
I wouldn't run anything bigger than a 350 jurnal on any small blk. In fact i run bear spacers on the 400 blocks and have for over 25 yrs. REASON, bearing heat, in fact NASCAR runs even smaller mains, i think Hink said they were running 2" mains VS 2.450 mains that a 350 has.
Hey Warren, didn't you know you could have bought a 2 piece adaptor for the crank you sold for less than $25.00.?
#8
If you go back and read Hink's post again, he is talking about an adapter for a one piece crank in a two piece block... I am not familair with an adapter for that setup either.
I do however have the above mentioned adapter for my two piece early crank in a one piece late model block, and it works very well
I really expected leaks and problems installing it, but it went in easy and so far has worked really good without a flaw...
#9
Actually Carl there are several companies making them.
Here's the china version, but you'll have to make an alienment bar to drill and tap the holes, or buy one from Speedway motors.
http://cgi.ebay.com/ebaymotors/REAR-...item35a52a9336
An American version.
http://www.race-mart.com/items/produ...800-detail.htm
Both Canton and Moroso makes them also and they are for sale at Jegs,Summit and Speedway motors, and the aleinment tool cost $22.00 on top of the adapter.
Dang it! I just sold my 3.875" stroker crank for an 1-piece rear seal because I couldn't use it in anything but an LT block. I sold it too cheap also!
Man you had me confused for a minute LOL
ops:
