Sealing scoop to carb
Old 12-22-2009, 04:06 PM
novadude72
Default Sealing scoop to carb
I am installing a aero scoop on my car wanted to know if i can use 3/16 aluminum plate or is it to heavy to mount directly to carb thanks.
novadude72 is offline
Old 12-23-2009, 09:59 AM
That sounds heavier than necessary too me. On my injection engine i'm useing 1/16" tk., because that's the material i already have, but .040 would be tk. enough.
Old 12-23-2009, 11:40 AM
TS1955
The panel between my scoop and carb is .040 and works fine. JMO!
TS1955
TS1955 is offline
Old 12-23-2009, 11:44 AM
oldandtired
oldandtired's Avatar
I used 3/16 on my door car and then crushed the foam about 20% with the hood to get a good seal. I was afraid the lighter stuff would flex.
Dave
oldandtired is offline
Old 01-01-2010, 08:01 PM
nitrotrucker
Default bonnett scoop
when i did my car i used a 14" aircleaner base and foam to seal carbie to bonnett worked real well
nitrotrucker is offline
