FLAT TAPPET CAM SPECIALIST
Old 12-23-2009, 12:09 PM
et7333
Default FLAT TAPPET CAM SPECIALIST
This is the current combo I am using in my drag car:
383 sbc,13-1,dart iron eagle 215 platinums,super victory,comp flat tappet,.558 550,260,[email protected] 108,ALKY 750 carb,3100 lb camaro
We are building a sbc Dart SHP 4.030 13.5-1 and I have a set of old iron eagles,not platinums that I might have some port work done on.The person who is porting the heads told us he will port the heads to 280 cfm @ .650,What FLAT TAPPET Cam Specs,NOT ROLLER,would you use? Remember this engine runs on Methonal.
Thanks
et7333 is offline
Old 12-23-2009, 05:43 PM
Loves Alcohol, worked good with Brodix T1 heads which flows between 270 and 275 out of the box.
