header a glow!
Old 12-25-2009, 05:34 AM
outlaw256
Default header a glow!
ok my friends, once again i have a need for your advice.i have a sbc thats built strong for the street. when we start this thing up and let it idle the pass. side header starts to glow a pretty red color.i thought that carb was set to lean so i play with the carb no luck.i have run into this before but i dont remember what i did to fix it. help please. thanks ken
outlaw256 is offline
Old 12-25-2009, 05:47 AM
itsabird
check valve setting on that side, may be too tight.
itsabird is offline
Old 12-25-2009, 07:15 AM
bbchevy
Default Glow
Also,a INTAKE Gasket Leak(Vac.Leak)?
Later
G 8)
bbchevy is offline
Old 12-25-2009, 04:18 PM
johnracer
Have you set your timing yet? Retarded timing will make headers glow ASAP............
Johnny
johnracer is offline
Old 07-26-2010, 06:45 PM
gsforless
JUNIOR BUILDER
I am currently fighting this same problem.
Fresh 355 flattop motor,Vortec heads,single plane intake,MSD ign,Holley DP carb.The thing runs fine,but after a couple mins idle time,the headers start to glow.They get to the point of melting the plug wire boots,just from the radiant heat.
I'll admit I haven't had a timing light on it,but I've moved the dist. all over the map with no luck and many a time in the past I have just dropped the dist. in,moved it where I wanted it and went with no glowing headers.
This is a hyd. roller cam engine.Is it possible for the valves to be too tight on it(as stated above)and it still run this good?Depending on where I have the dist. sitting it sometimes grunts during startup,but the throttle response is great,it runs smooth,etc.
I did pull the intake back off and put another new set of gaskets on it(Fel Pro 1255s).While I had the intake off this time I drilled some extra holes in the intake to match some that had been previously added to the heads(by someone else) and the 1255 gaskets already had both sets of holes.So basically it now has both intake bolt patterns(minus the two front and two rear holes in the "old" style pattern-they werent in the heads,so I didnt put them in the intake),and has a total of 16 bolts holding the itake on!I also used the Permatex plyable non-hardening sealer on both sides of the gaskets for insurance.I seriously don't think I still have an intake sealing issue(if I even did in the first place).
Does anyone have any other ideas?
Thanks,
Glen
gsforless is offline
Old 07-27-2010, 06:45 AM
oldandtired
oldandtired's Avatar
Default Re: Glow
Later
G 8)
x2
oldandtired is offline
Old 07-28-2010, 12:05 PM
  #7
toohipz28
Advance your timing!!!
toohipz28 is offline
Old 07-29-2010, 04:39 AM
  #8
jmarksdragster
jmarksdragster's Avatar
Johnny
Yep.
jmarksdragster is offline
Old 07-29-2010, 03:41 PM
  #9
Scooterz
Johnny
Yep.
In my ongoing learning I ran into this very same issue on/a BBC. Pass side header was glowing near collector area & made the header paint turn white on that side. I painted it again & advanced the timing & re-set the solid lifters on that side. One int & one ex lash was off by .200. fired up & drove... problem solved. Black paint still black, more responsive, etc...
Scooter actually figured out something on his own.... amazing.
Scooterz is offline
