powerglide questions
JOURNEYMAN
Hello All:
Looking for some opinions from the powergide pro's. I was having issues with fluid leakage from the rear seal.When the boys rebuilt my glide they said the rear cover was tore up.
235 " rear engine dragster
hard tail
shortyglide w/brake
I did feel the car bounce going on the stop and also had issues with tire/spin tire/chatter from 330 on. ( off the stop)
Question
Did this issue occur from tire bounce/spin?
Do i have a alignment issue occuring?
Do i have no idea what i'am talking about! (best answer)
Any Opinions
Thanks Mike
hard tail
shortyglide w/brake
Question
Any Opinions
Thanks Mike
Mike is this a coupler or driveshaft ?
I've never seen bounce/spin cause a issue before, I've ran some crappy tracks with hardtails and never had a issue. Is it just leaking around the seal itself ?
Mike
You very well could have early signs or alignment issues. I spent some time talking to Don Higgins from Crew Chief Pro. His car had a slight bend in the rear frame. This took the rear out of alignment and tore up a lot of things. I would check for square as a start. Will the bounce hurt it, not most likely the case but I would not rule it 100% out. Have you had your builder take a look to see if he can offer up some advice?
JOURNEYMAN
Guy's
Started to tke things apart and yes it is a alignment issue. Old Old hardtail car with coupler.I think also there may be a rail that bent. I will get it apart this weekend and resquare the motor/trans new mounts etc and keep saving for a new car in 2011.
Thanks all
Mike
Thanks all
Mike
#8
JOURNEYMAN
Sorry for the delay, been racing.
After i cut the mid mounts out and realigned ,yes i can slide the coupler.I was able to before, but i think i tweaked the rail. I have now reenforced it and so far (6 passes), everything is looking great! Now if i can just convince my wife i need a new car!
Mike
Mike
