leaving valve seals off???
I don't run seals, if you remember chevy never put seals on their gides, just an O ring under the keepers and this on a street engine. The guides needed a little oil to keep them from wearing, and most did after a 100,000 miles, IE the little bit of blue smoke on cold startup on and old engines. Ford ran a little mushroom bonnet type seal, which is what i use on uncut heads. With the advent of bronze guides and alum heads they came with seals, because the guide were an oil impragnated bronze, but on strickly racing engines we cut back on the oil to the top of the engines, with roller lifters and rockers, and usually only a mist of oil on top, that why i don't use them. But as mentioned in an above post, if you are running a vacuum pump, they are probably a necessary idea. I've only ran an evac/header system, no experience with vacuum pumps.
#8
CRAFTSMAN
I have talked with several old timers on this subject, and last season Mike strausberg was at our track, his mechanic builds my friends Engines and I asked them this question. They build all race motors, NITRO, or race fuel withOUT EX valve stem seals. They said " The Ex valves do alot of work and take alot of heat, so not running the seals gives a little extra room for oil on the stems for lubrication and cooling, they can get more life out of them this way. I ran seals on them last year but when I re built my heads for this season I did not install them. I hope this helps and makes since.
I also questioned my machinist and he also agreed as long as its not a street motor dont run the seals on the Ex valves.
#10
JUNIOR BUILDER
Id leavem off.. Especially with a triple spring. They usually get chewed up. I dont remember the last time i had seals. Remember our 300' pass is ALOT longer than a 1/8 or 1/4 run. Stuff has more time to build heat.
