brake problem
Old 04-04-2010, 01:01 PM
ssmonte70
APPRENTICE
Default brake problem
i have a 70 monte put new rear drum brakes and new disc brakes in the front, when i got the car it only had the master cylinder i put the brake booster, i blead the brakes and not geeting a good pedal will it help to hook up the vacuum line from the booster,
ssmonte70 is offline
Old 04-04-2010, 03:35 PM
fla1976
fla1976's Avatar
Power brakes won't work correctly without the vacuum line attached and the engine running.
fla1976 is offline
Old 04-05-2010, 07:46 AM
ssmonte70
APPRENTICE
weres the best place to pick up the vacuum from
Old 04-05-2010, 12:13 PM
oldandtired
oldandtired's Avatar
Intake manifold...
Good luck, Dave
oldandtired is offline
