jetting carb
Old 06-10-2010, 02:16 PM
greenone60
JOURNEYMAN
Default jetting carb
i have a jetting ? when the weather gets hot do you go up(rich) on the jet sizes or do you go down(lean) and ideas. 1/8 mile drag car with sbc running 114 sunnco race fuel.single carb 850 holley hp
greenone60 is offline
Old 06-10-2010, 04:08 PM
wrightway
SENIOR BUILDER
Down
wrightway is offline
Old 06-10-2010, 04:20 PM
curtisreed
curtisreed's Avatar
Originally Posted by wrightway
Down
X2
curtisreed is offline
Old 06-12-2010, 10:19 AM
chevyart
Default hot weather
what do you guys do with the timing in the real hot weather. up, down, or leave it as is ? thanks chevy art
chevyart is offline
Old 06-22-2010, 05:44 AM
chevyfireball
When the weather gets hot or the altitude goes up, the air gets worse so you can't burn as much fuel so you need smaller jets. I usually only alter the jetting two sizes.
I only alter the timing when the car is over powering the track (retard it 1 - 1 1/2 degrees. If I'm wanting to set her on kill I advance it 1 - 2 degrees. Just make sure you're checking your plug condition after each run to avoid detonation etc.
chevyfireball is offline
Old 06-22-2010, 09:21 AM
JEFF69Z28
over powering the track= spining the tires?
JEFF69Z28 is offline
Old 07-02-2010, 04:30 AM
  #7
chevyfireball
Yep. Some tracks aren't prepped that well. With a glide, convertor and nitrous motor there aren't too many options to get traction without losing too much power.
Old 07-02-2010, 12:26 PM
  #8
Tod74
I never mess with mine. I leave it the same all the time.
Of course I also lose in the first round most of the time too. :lol:
Tod74 is offline
Old 07-05-2010, 10:24 PM
  #9
cepx111
I agree, hot/humid weather likes a leaner A/F ratio.
Jetting it down will aslo make it more consistent if you race where theres a temp drop from TT's to elims , E.G> daytime TT & nighttime racing.
I jet for consistency - not power/ET.\
Cp
cepx111 is offline
